No throttle 2012 mustang v6
pub154
Post by pub154 »
I just got i2 today and installed tune for my 2012 mustang v6 revs up fine in nuteural sounds nice go to shift in first gear and drive goes up to about 2000rpm and stops no more throttle shift to nuteural and rpm stay at 1200rpm shut down car and turn it back on works fine then same thing need fix or to return product and refund my money thanks
Re: No throttle 2012 mustang v6
did you disaBLE THE SPEED LIMITER IN EASY TUNE?
IF SO, USE ADVANCED TO DO IT AND IT WILL WORK FINE :)
tech@diablosport.com
pub154
Post by pub154 »
Yes I did use easy tune and also used advanced and it did the same thing
pub154
Post by pub154 »
Have updated i2 this morning to try again now it won't connect to the car has been on please wait for quite some time
pub154
Post by pub154 »
Ok it's been on please wait for over 30min brought it back in to check if maybe it needed an update again and says it doesn't still won't connect to car
please post the info.xml file from the i2 drive.
pub154
Post by pub154 »
think this is it
is it booting to the main menu now?
pub154
Post by pub154 »
It works fine when I connect it to the laptop gives setting option and when connected to the car turns on fine I hit tune button and says please wait and won't connect and if I shut the car off and hit scan bottom won't connect either
lets reset it, go to settings/advanced/tech support/advanced/registry reset, and type out the key and wait there for my reply.
pub154
Post by pub154 »
Ok tried to reset it like you said keeps telling me failed
pub154
Post by pub154 »
Ok disconnected i2 reconnected it and typed out numbers and letter haven't done anything else
Im asking you to type out the key here so I can give you a password.
pub154
Post by pub154 »
8FA48E5A2AB70D57DD7DD792E94799BE8F452B7C
click Ok then enter this:
F43CED0A0C3CB1387C86
then OK and it will reset, then give it another shot.
