No throttle 2012 mustang v6
Re: No throttle 2012 mustang v6
it reset thanks and try it on car now in advance right???
correct.
tech@diablosport.com
Sorry to get back so late it worked so far but didn't ask to remove speed rev, tire size, or gear ratio does this let me go faster than 120mph now??? And smoke my tires??? Just installed it had gotten busy with work drives fine feels a bit different haven't gunned it yet
in advanced you casn select the modify tune option and change lots of stuff
Came to change speed on car in advance settings again and same problem happened no throttle and i2 started going back on its own and installed 93 octane then it installed 91 octane so I unplugged it and reconnected it was able to install original back up....not happy on what's going on what do I need to do to return i2??? And refund my money back???
can oyu load the tune then post the backup and last tune written here before you restore the stock tune so we can check this out?
Have already installed original tune the i2 started going back and installing tunes on its own after it was done I had shut key off and unplugged it I reconnected it and installed original tune shut the key off and have put it back in the package with what it was doing didn't want it to change other stuff and jack up my car have put $12,000 into it and would want a refund so I can get a better tuner from u guys a bit later I have an eye surgery coming up so car will be parked till I can be up and around again, long story short I have my eye ball still but large freak accident left me blind and need multiple surgeries still was trying to have a lil fun before months of bed rest again
Anything to return it???
contact the retailer, should not be a problem.
The person I bought it from??? He told me since I connected it already that I had to contact you guys to return it
No, we offer a 30 day satisfaction guarantee, restore the stock tune and he should take it back no problem.
