Racing Module
Racing Module
I have a 2012 F-150 with ecoboost. I purchased the Trinity 1000 and installed the 93 tune after I changed out my plugs and set them to .029. What a difference it made. I love it. I'm having a problem getting the "Racing" module to work. I go into it, select 0-60 then motion start and nothing happens. I also tried it on the tree with the same result. Any help would be appreciated. Thanks.
Re: Racing Module
we're sorting this out currently.
tech@diablosport.com
Re: Racing Module
Mike, are you still working on this?
Re: Racing Module
sorry, it got held up in engineering but is still being addressed.
Re: Racing Module
Go to the logging menu and then hit restore default dashboards while plugged into the vehicle and key on. Should work then provided you are on the latest update. I tested it yesterday morning.jb300mag wrote:Mike, are you still working on this?
Insert Clever comment here...
Re: Racing Module
I will try it out. Thanks.
Re: Racing Module
Still not working. The drag tree worked once but won't work again. The motion start has not ever worked. My tool is 2.2.2.11 which appears to be the current version of the software. What should i do? Thanks.
Re: Racing Module
whats the version on the trinity under options/show information.
Re: Racing Module
I will look tonight and get back with you. Thanks.
Re: Racing Module
My Trinity version is v.1r13I
Re: Racing Module
so right now the drag tree never connects, even after restoring default layouts?
Re: Racing Module
I restored the default layouts several times and the drag tree worked once but the motion start has never worked. On a side note the one time the drag tree worked it did not stop when I reached the set speed of 60 MPH so I could not determine how many seconds lapsed.
