2012 F150 5.0 no throttle response
jackstand
Post by jackstand »
I have the i2 and installed the 87 octane tune this morning, went to drive the truck to work and did not have any throttle response truck would idle around 2000 rpm but would not change with throttle movement.
Re: 2012 F150 5.0 no throttle response
did you load the tune through easy tune and disable speed limit there?
If so, please use the advanced menu to disable the limiter and it will work fine.
tech@diablosport.com
jackstand
Post by jackstand »
Thanks mike worked perfect
Goose
Post by Goose »
mikel wrote:did you load the tune through easy tune and disable speed limit there?
Glad I got on this forum.
I was having the same issue with my 2015 F150 3.5 ecoboost.
Idles but pedal is dead when put back to stock tune no problem.
this is a different issue, we can provide a customtune to correct it for now, please post your backup here or in the thread specific to ths issue under general support.
