2014 5.0V8 F-150 Dead Throttle
Was having trouble programming the 87 Ocatane easy tune, whenever I went through the tune whether I disabled the speed limiter or not, it would idle around 1800-2000RPM and the accelerator wouldn't give me any throttle. Trouble Codes show a PCM: Speed Limiter Problem. Is there something that I am missing? Thanks for your help.
Re: 2014 5.0V8 F-150 Dead Throttle
use advanced tune to disable the speed limiter, its a bug with easy tune.
tech@diablosport.com
Will do thanks,
So just better to bypass auto tune all together and use advanced to turn the limiter off? Or just go through tune with advanced, turn the limiter off, and then go back through easy tune?
no, once you do advanced there is no need to use easy...easy is just there to make things simple, but they both load the same tunes.
Great,
Thanks again for you help and clarification!
