2000 Ford F-350 won't tune with i2020
Today got the i2020, was beyond excited. Ran straight home ran the updates on the tuner. Went out plugged it into my truck. Went to tune my truck, the tuner loaded a screen saying"VIN not available. Attempt to manually enter VIN?" So I enter my vin I punched in all the number and letters to the T. Loaded for a bit, then a screen popped up saying the following "This vehicle is currently not supported; an update may be required. Please plug the i2 into a PC to download any updates" I've tried updating it multiple time to no success, and attempted to tune it a bunch of time. On a side note I was recently in a vehicle accident with the truck air bags deployed. No where in the paper work did it mention a replaced PCM but could this having something to do with it??
Re: 2000 Ford F-350 won't tune with i2020
please post the info.xml file fromthe oi2 drive and I will make the update for you.
The VIN netry is not uncommon on these early trucks, once you load the cal update it will write the VIN to the pcm so you wont have to do it anymore.
tech@diablosport.com
Awesome I will upload the file as soon as I get home
Here is the file from my tuner. Let me know what to do, thank you.
the server is fixed, you should be able to run the updater and get the file.
its attached here as well, save to the i2 drive and let the device import it or run the updater to get it, then load the update to the truck.
