JLT91 running very lean espec. on throttle LTFT@17
gabegarcia076
Post by gabegarcia076 »
please adjust the fuel or WOT. i added 5 to MAF because at default, it was idling bad
07092017jlt91.log
Data Viewer Log JLT91
(366.99 KiB) Downloaded 466 times
RXAP9N5_ORIG_07092017.frg
(852.25 KiB) Downloaded 471 times
RXAP9N5_JLTprem_07092017.frg
JLT 91 Octane Last written File
(5.25 KiB) Downloaded 457 times
Re: JLT91 running very lean espec. on throttle LTFT@17
is this the new JLT S3?
tech@diablosport.com
gabegarcia076
Yes
DiabloMatt
Post by DiabloMatt »
i dont have a curve for the series 3 truck intake. but this should be close. load this in there and let me know
RXAP9N5_ser3jlt.frg
(852.14 KiB) Downloaded 457 times
gabegarcia076
Thank you will do tomorrow
gabegarcia076
Loaded it, sounds good but 2 codes P1000 OBD system readiness rest not complete
P2196 02 Sensor signal stuck rich bank 1
Lift both at
MAF
stay both above 25 to 28
In idle after 10 min warm up
sounds like a bad O2 sensor...
gabegarcia076
But when I load the 91 JLT tune with +5 MAF it works okay. Just my short trim fuels are at 15 at idle. How so i adjust that? The file is above
