Board index (Legacy) Predator Technical Discussion Predator Ford Gas f150 EB3.5 P2282
f150 EB3.5 P2282
Post Tue Jul 18, 2017 4:32 pm
I have a thread going in the itune section but it should be in this thread as im using the predator PN7102.
Called you guys today for a tech call as im having issues with check engine lights. Techs are checking things out I guess but just want to let you know code that is thrown is a P2282. 2017 F150 EB3.5
does not show a CEL on the dash but when plugging in the device it shows up in the DTC section.
Post Thu Jul 20, 2017 5:54 pm
Anything?
Post Fri Jul 21, 2017 11:53 am
when you called in id anyone ask you to send tune files or the info file?
if not can you post the info.xml file and the files from the tunes folder here so we can check them out?
561-908-0040x4
Post Sun Jul 23, 2017 11:21 pm
I cant locate the tunes folder or a file called tune.xml?
Post Thu Jul 27, 2017 8:07 am
sorry, I was thinking intune.
when you called i were you asked for your serial number?
were you given a case number?
561-908-0040x4
Post Mon Jul 31, 2017 1:04 pm
No case number given. Was just told on the phone that it was being looked into about ghost codes.
Post Wed Aug 02, 2017 1:07 am
over 3 weeks old guys...any updates as to where we are heading with this? I cant use the tuner at all in its current form.... :roll:
Post Wed Aug 02, 2017 9:52 am
do you have any drivability issues when the code appears?
561-908-0040x4
Post Wed Aug 02, 2017 12:10 pm
yes. The truck jerks very hard and the traction control flashes on. Also threw a wrench code one time and was forced to pull over and clear codes with the programmer.
Post Wed Aug 09, 2017 10:41 pm
hey guys,
I'm trying to be patient and all, but its been over a month now at this point and all tunes are completely unusable in their current state. Are we getting anywhere with this? Any updates to be had? :|
Post Thu Sep 14, 2017 10:12 pm
Couple months now. Unit is still throwing codes after the update I received. P2282 and p099a/b
Post Fri Sep 15, 2017 8:06 am
this is in the engineering queue to be looked at, they are trying to source a vehicle that replicates the issue.
Sorry for the delays.
561-908-0040x4
Return to Predator Ford Gas
cron
