How to restore factory settings
I received a new I2. My old one was corrupted and the new one arrived today. I tried to put a new tune on my 2014 Sierra 6.2 but it tells me to restore to factory settings and start anew. How do I do this? That option is not available to me. I have gone through every menu and nothing for restoring to factory settings is available.
Re: How to restore factory settings
post up the files the device read out.
tech@diablosport.com
Here is the XML. Not sure if this helps.
<?xml version="1.0"?>
-<tool_info platform="I2">
<registration updates="0" tool_oem="DIABLO" status="0" sn="1QQGPUNJN8"/>
-<applications count="5">
<application rev="2r01z" name="vehicle"/>
<application rev="2r01e" name="updater"/>
<application rev="2r01o" name="gui"/>
<application rev="2r01i" name="installer"/>
<application rev="2r01a" name="logger"/>
</applications>
-<databases gui="2t01ha" vin="2r01h" dtc="2r01a" dbnames="2r00">
<database pid="2t01et" tune="2r01r" mfr="DCX"/>
<database pid="2t01dk" tune="2r02m" mfr="FORD"/>
<database pid="2t01cr" tune="2r03h" mfr="GM"/>
</databases>
-<system rev="1r01b" config="1r01d">
<option name="Wifi" driver="v4.0.2_9000.20130911" enabled="true"/>
</system>
-<last-connected vin="3GTU2WEJ2EG399917" mfr="GM" ecus="2">
<ecu calid="12660065, 12660176, 12659579, 12625016, 12642482, 12651982, 12645344, 12660179"/>
<ecu calid="24270599, 24270734, 24272346, 24270737"/>
</last-connected>
<licenses tuned="0" available="1"/>
<unsupported vin="3GTU2WEJ2EG399917" calid="12660065, 12660176, 12659579, 12625016, 12642482, 12651982, 12645344, 12660179" oem="GM"/>
<reg reg="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"/>
</tool_info>
</applications>
</databases>
</system>
</last-connected>
</tool_info>
I need the files it read out, which will be in the tunes folder.
Here is the only file in the tunes folder
ECM_12659579_BackupDiabloTune.grg
you need to ATTACH the file to your post.. so mikel can download your tune file..
here you go
at any point were you advised to grab a copy of the backup files from the first device, or to send them to one of the techs here?
