I have a 2006 1500HD 6.0 I am wanting to add elect fans to it, using the stock 05'ish OEM truck fans and use the LS1fans.com wiring harness. What steps would I need to do to accomplish this with my I2 tuner? Is it a custom tune only? I assume it is possible with my '06 HD?
Thank you, Mike
Adding elec fans to 2006 1500HD
Re: Adding elec fans to 2006 1500HD
post up the backup and last tune written files and we'll enable it for you.
tech@diablosport.com
Very fast, thank you. I hate to say it, but kinda computer dumb. How would I go about posting those files? Is it in one of these?
Is this correct Mikel? Has Stock cooling and stock Thermostat.
yes that's them... here ya go..
download this tune to your computer.. connect the intune to your computer and let it start up..
copy the custom Fan tune file from your computer harddrive and paste it into the main i2 drive..
do not copy it into any of those subfolders! You just need to copy it to the main i2 drive.
the intune will show a message when it's been imported..
then you can go to vehicle and go to Tune Vehicle - Advanced Mode.. Custom Tunes.. select the custom Fan tune listed, and install it.
you don't have to change anything else. .your tire size setting is already in this custom tune too.
Thank you Lew! What temp did you set the fans to start at, for low and high speeds? Just so I can watch my coolant temp gauge
All other changes I had (shift firmness, speed governer etc) were copied over also? Can I modify things on that custom tune file, without messing it up? Or is it install it only and cant adjust?
Mike
Mike
any changes you had made before yourself, are still there.. they're already in the custom tune. you can modify the custom tune just like any of the preset tunes.. but as I mentioned, anything you had already adjusted before, those settings are still already in the custom tune..
Thank you Lew.
Am I able to make changes to the custom tune later, for shift firmness etc? Without messing up the fan settings?
yes
Lew, do you remember what temp the fans turn on for LOW and HIGH speeds? Thanks.
no.. but it was at least 20*-30* lower than stock... somewhere around 199-205, 207-215.. something like that...
