Board index Trinity Technical Discussion Trinity Dodge Gas Programing sets a P1400 AFTERMARKET CALIBRATION DETECTED
mikel wrote:
idangerous wrote:
If I buy a CMR License can I turn this code off myself ?
Ill turn it off in the tune, b ut it doesnt truly resolve the issue.
Code will come back if dealer flashes the pcm or if stock pcm is reinstalled.
So if you turn it off in the tune on an unlocked PCM, would the Dealer be able to detect that there is an unlocked tuned PCM in the vehicle with the code shut off in the tune ?
dealer can only detect what the pcm tells them, so if it doesn't throw the code they have nothing to check for or reason to look.
As mentioned, if they flash the pcm or replace it, the code will then appear.
561-908-0040x4
My dealer saw 2 things, the p1400 code with the aftermarket calibration, and a non OEM PCM part number, from when the unlocked one was installed. So seems like they will see the different part number even if they dont see the code.
Is there any possiblity of adding the option to turn off this code with the Trinity ? :roll: :normal:
it an be disabled in a custom tune as previously mentioned, but its not a 100% solution.
561-908-0040x4
Has anybody tried replacing and reprogramming the BCM?
Ive seen dealers do it to get rid of the code when they were confused as to why it was there or where it came from ;)
PCMs ordered for any Car application for the past 3 weeks or so no longer trigger this code when installed.
561-908-0040x4
Still nada for those of us with the code? Wouldnt a dealer need to program a new BCM? Kinda doesnt help really since they know it was there and reported already no?
Is there any progress toward finding a solution for your customers who installed an unlocked PCM and tune, purchased from you, and now have a P1400 code that may be grounds for having their factory powertrain warranty restricted if they bring their vehicle in to the Dealership for service or repairs ? While still advertising that the Dealer can not detect your product when used as advertised ?
:normal:
:normal:
It is quite clear they don't care about this. They sold a product that was not as advertised. Might be time to look into legal action for a resolution. I can say for sure, I will never buy a product from them again. I've had a few of them over the years, the customer service side leaves quite a lot to be desired.
I will provide a custom tune to disable the code for anyone who would like that.
561-908-0040x4
What happens when the stock pcm is put back in for dealer/warranty service? Is the code gone, or does it come back?
Just noticed this on my 17 Jeep Grand Cherokee 5.7. I have an i2.
I think the solution is new Diablo PCM, new oem BCM, then you have to have dealer perform "restore configuration" on new BCM with original PCM installed. This downloads the original configuration from chrysler server for that VIN.
Problem is, all the $ it would cost to give everyone new PCM and BCM, and then hoping your dealer runs a "restore configuration" for you. DS could download for each VIN and send a software update to reconfigure, but this is obviously a huge task for them. It's a lose / lose for us...
It's clear Diablo could give a crap about this. They got their money is what it comes down to. I'll never use their garbage products ever again. Customer service goes a long way, which for them is non existant.
Hello,
Just wondering if this issue is resolved for 2015 JK Jeep sport?
Would the dealer know if I swapped the tuned PCM with the factory original Locked PCM.
Will it show a trace or P1400 code or any other code or log?
Also when installing the PCM issued by Diablo and talking the Factoy PCM, would that be detected by the dealer.
I am looking to buy the Trinity 2 for Jeep with PCM and custom tune for off-roading in Sand Dunes.
Wanted to know if this product “Trinity2 + PCM” would compromise my warranty by being detected.
Cheers
@mikel
PreviousNext
Return to Trinity Dodge Gas
cron
