Board index Trinity 2 Trinity MX monitor Temp Gauges
Temp Gauges
This section of the forum is for discussions relating to the Trinity MX line of monitor devices.
Post Sat Jul 28, 2018 7:01 pm
Hello just curious if Trinity 2 MX will display temp readings in particular Transmission Temp and Car oil Temp
Thanks in advance for info
Post Mon Jul 30, 2018 9:27 am
What vehicle?
Engine oil temp is not normally something the PCM monitors...
561-908-0040x4
Post Mon Jul 30, 2018 5:04 pm
And on GM vehicles, the tranny stuff is not and can not be monitored at all.. only the engine parameters/PID's can be monitored, nothing for the transmission..
Again, I'm talking about 2007+ GM vehicles... it may or may not be the same for Ford/Dodge/Chrysler/Jeep...
Post Wed Sep 12, 2018 2:32 pm
A 2008 Pontiac GXP had a onboard info center that included transmission temperature. I guess that was through a temp sensor unable to be read by the ECM? Just curious. Actually all the LS4 GXPs had that.
Post Fri Sep 14, 2018 3:07 pm
Trans temp is different. PCM often monitors that for various reasons, and the PID can be sent from the TCM or PCM in different applications.
Engine oil temp is not often something the pcm is monitoring in all cases.
561-908-0040x4
Post Fri Sep 14, 2018 6:39 pm
Only interested in Transmission temp. Oil pressure and transfer temp. So unless I'm reading your reply wrong it can be done. If so can you send me a file to apply to my Trinity 2? Heat is what destroys these 4T65-HD transmissions. I have a cooler but would love to keep a eye on it.
Post Mon Sep 17, 2018 8:03 am
No, I dont mean to keep confusing things here.
TCM PIDs for GM are not something we can display on our devices at this time.
561-908-0040x4
Return to Trinity MX monitor
