Board index i2/i3 Technical discussion i2/i3 for Ford vehicles i2 Compatible with analog cable?
Post Mon Aug 27, 2018 7:31 pm
My Lightning has an AEM UEGO wideband (though it does need a new Lambda sensor). Can I use that with the i2 for logs? I believe its a white wire from the gauge? There used to be a cable you sold for the original Trinity (T1015?), but I'm not seeing that anymore. Is it available still and will it work with the i2?
Something is not right with this truck. It reeks of fuel and oil when running, won't hold boost and is S-L-O-W. Its got a lot more mods than I realized, so I'm wondering if it has injectors too and could be flooding.
2017 BMW X3 xDrive35i
BMS Stage 1, aFe Drop in.
2000 Ford F150 SVT Lightning #3990 of 4966
6#, FBO. Not running right.
2018 Chevy Equinox LT 2.0T
2015 BMW 335i GT #1 of 1, as equipped
MPPK FBO.
404whp, 435wft/lbs
Post Fri Sep 07, 2018 3:16 pm
can usually tell what injectors by looking as I recall, especially with the fords of this era.
What MAF....no Mafia?
The AEM will work fine, the T1015 is still around, and the SRT4 guys used to use a cable from ebay from digitec as I recall.
561-908-0040x4
Post Sat Sep 08, 2018 11:03 pm
The injectors appear to be stock. They're the same green color as stock, once the disgusting crap is scrubbed off them.
Stock 90mm 01-04 Lightning MAF. Do I need a MAFia? I thought it was handled by the tune.
I'll pick up the T1015 so I can log the wideband. Got some new midpipes and cats, so I need to have a bung installed for the wideband too. Couldn't believe both precats were completely oil fouled.
MPPK FBO.
404whp, 435wft/lbs
Post Mon Sep 10, 2018 7:27 am
Stock 90mm MAF and injectors will support around 425 rwhp on these as I recall, so it can't be too crazy :)
561-908-0040x4
Post Fri Sep 14, 2018 2:36 pm
How do I add parameters to the log that aren't listed? I mean there are things I'd kinda like to see, that I'm not finding anyplace, like MAP, KR, maybe even boost. I was shocked at how few parameters were showing up compared to the Chrysler LXs.
No rush. She's down for at least the next week. Waiting for an intercooler core. Mine popped and Ford doesn't make them anymore, so aftermarket is the only way to go, with a 10 day lead time.
MPPK FBO.
404whp, 435wft/lbs
Post Fri Sep 14, 2018 3:02 pm
in the logging menu go to the configure menu then select add PID. MAP is not a standard pid for logging EEC. I am not sure if it will even have a boost pid or not, I dont recall on these earlier vehicles.
561-908-0040x4
Post Sun Sep 16, 2018 7:03 pm
I hit up Mike at TPC, so hopefully it records enough for him to make a tune for it, without completely knowing whats on it. Of course, thats when its fixed. Still waiting on the core, a 6# pulley and even colder plugs.
MPPK FBO.
404whp, 435wft/lbs
Post Mon Sep 24, 2018 9:19 pm
So Mike, do I need a MAFia with the SCT MAF? I was told I needed that MAF for a 6# pulley, so I picked up a BA-2600. Wish I could just come up to you guys and have it dyno tuned.
MPPK FBO.
404whp, 435wft/lbs
Post Tue Sep 25, 2018 3:55 pm
No, the BA2600 is like a MAF with a built in Mafia. It should be fine on its own.
Where are you located?
Mike may be down to have you bring it up here and do it on a weekend....
561-908-0040x4
Post Tue Sep 25, 2018 5:32 pm
I'm in Winter Haven. About an hour and 20 minutes south of you.
MPPK FBO.
404whp, 435wft/lbs
Post Wed Sep 26, 2018 7:42 am
Ahh, I had no idea. Thought you were still up north but I remember you talking about moving down here a while back.
Yeah, let Mike know you are somewhat local and maybe he can work something out.
561-908-0040x4
Post Wed Sep 26, 2018 5:48 pm
He'll probably see this. He said he's been reading the thread.
It's going to be a while longer before the truck is ready. Just talked to the distributer and the core is taking longer than normal. They've had lots of customers with grenading stock cores this year apparently. Guess 18-19 years is about all they can handle. Meanwhile, my truck is sitting at the service shop, with the top of the motor open and they call me every day to see if the core came in. And every day I have to tell them not yet, but I have other stuff that needs to be done if you want to do it while access is good. It would be much easier to do the plugs and T-stat now while the blower is off and there's space to work in, but they aren't interested. :cry:
MPPK FBO.
404whp, 435wft/lbs
Post Sun Dec 16, 2018 8:25 am
No rush. She's down for at least the next week. Waiting for thérapie de groupe an intercooler core. Mine popped and Ford doesn't make them anymore, so aftermarket is the only way to go, with a 10 day lead time.
If the i2 tune is not ready with 5.0 tune can you advice on what tuner is available for the 2018 5.0 F150?
Return to i2/i3 for Ford vehicles
