Having trouble importing CMR tunes into a I3 P . Was perviously working and cant figure out the problem now.
Just trying to load a slightly modified tune attached to get things working properly.
I3 Platinum will not import CMR tunes
Re: I3 Platinum will not import CMR tunes
will the file import and not show up, or simply will not import at all?
Can you post the backup and info files as well please?
tech@diablosport.com
Mike I found out the issue I was having importing files to tool. I looked into the tune file I had been trying to load and noticed the VIN number was not in the end WHITE message/ Notes box when saving. Put the vin in all CAPS into that box and issue solved. I am now having a tuning issue on this vehicle. for some reason the Cold start enrichment is overcompensating and flooding out on sub 40 degree mornings. in my location it was 55-60 degrees and it was a bit grumpy but started. I have played with different settings with no prevail. Any Info on this one? Attached is most recent tune file.
Thats above my pay grade
Please shoot the file and a log over to cmrtech@diablosport.com so the calibration team can check it out.
