Board index Trinity 2 T2 for Dodge/Chrysler/Jeep/Ram T2 problem Jeep Wrangler
Post Wed Dec 05, 2018 4:01 am
Hello,
I recently bought Magnusnon supercharger, with it i get T2. I went step by step according to the manual, upgrade T2 through Ignition (twice) when I connect it to the vehicle and tap on Tuning I get this msg "There are Control Units in this Veicle that are currently not supported...." so i tried to update once more and it is stuck on updating 2/2. I tried it several times, it's still the same. Adding info.xml
Post Wed Dec 05, 2018 11:21 am
theres an issue with our server, it should be resolved shortly and you'll be able to get the updates.
561-908-0040x4
Post Thu Dec 06, 2018 1:54 pm
Now i tried update it once more this is what i get
Post Fri Dec 07, 2018 4:17 pm
copy this to the t2 drive and let the device import it then load the update to the jeep then you can tune it.
561-908-0040x4
Return to T2 for Dodge/Chrysler/Jeep/Ram
cron
