2018 Mustang EB Ever getting tune?
Is there ever going to be a tune for it? 2019 is already out and 18 isn't supported yet.
Re: 2018 Mustang EB Ever getting tune?
I believe it is planned, yes. I do not have an ETA but will follow up on that.
tech@diablosport.com
Thanks, I bought the Ford license few months ago figuring it was out already.
Tried updating i2 tuner for the 18 EB. It tells me everything is good but when I put it on the car says not supported. Try updating again and the same update try's to update again. And I get the same not supported. this just keeps happening over and over.
Pleas epost the current info.xml file from the device so we can check this out.Sam5828 wrote:Tried updating i2 tuner for the 18 EB. It tells me everything is good but when I put it on the car says not supported. Try updating again and the same update try's to update again. And I get the same not supported. this just keeps happening over and over.
mikel wrote:Pleas epost the current info.xml file from the device so we can check this out.Sam5828 wrote:Tried updating i2 tuner for the 18 EB. It tells me everything is good but when I put it on the car says not supported. Try updating again and the same update try's to update again. And I get the same not supported. this just keeps happening over and over.
Hopefully, I have it working now, I downloaded all the other files from your downloads section.
When I try and do the updates through the updater it reverts back to older versions of things. Also when I try the WIFI config it just freezes and I have to reboot it.
Well still says not supported
OK, we'll get this one added, and let you know as soon as the update is ready early next week, sorry for the delay.
Thanks Mike.
Any luck with this?
Should have the update ready today, its in the works. Thanks for being patient with us.
Thanks, Just let me know when it's readymikel wrote:Should have the update ready today, its in the works. Thanks for being patient with us.
sorry for the delay, update is attached.
Save it to the i2 drive and let the tool import it then tune the vehicle.
