Board index Trinity Technical Discussion Trinity Dodge Gas Write failure/Calibration issue
Post Sat Feb 25, 2017 4:59 pm
This is on a 2006 Dodge Magnum SXT RWD 3.5L, VIN2D4FV4716H124211. I was performing a Performance Tune using a Trinity T-1000 Ser#6OHX71D software DSDL ver 2.3.1.0 and DSUSBDL ver 2.5
Display info: 1) Write failed (failsafe). Pleas make sure the ignition is on and the engine is Not running. 2) Update did not finish, Calibration update via DSDL was completed successfully, press center key to update vehicle calibration.
I went through this process several times key off and key on fails and repeats. My vehicle at this time is inoperative. What are my options, please help.
Sincerely,
Ray :?
Post Thu Mar 02, 2017 4:59 pm
disconnect the battery cables, touch them together to drain voltage then reconnect and plug the tool back in and try letting it restore again.
561-908-0040x4
Post Sat Mar 04, 2017 9:32 am
This cable process did not solve my issue. I had to send PCM and Trinity T-1000 with cable to Diablosport location in Florida for my PCM and Trinity to be checked out further. I received my PCM and Trinity back two days later with Recovery Team letter information include.
Results: Please Do not attempt to use this tool again. IT will make the vehicle not start.
We have found a bug in the software or the file the tool is requesting. We are not sure when we can fix the issue. So if you just have just recently purchased this tool it might be a better option to return it.
If you have had this a while a periodic email to support@diablosport.com may indicate the status.
Your calibration ID is 05094696ae
The tool wants to put the pcm on AD and will repeatedly fail. Causing a no start issue.
I have updated your rma 138881 with the notes I have presented you
Recovery team.
My PCM is operating with it's stock tune and vehicle running well. I thank the Recovery Team for all their help on this issue.
I have contacted the online site on returning the Trinity and having my funds returned to my account. I will try again at a later time when I'm more assured of the tool operation.
Post Mon Mar 06, 2017 12:26 pm
thanks for understanding, we're looking into this.
561-908-0040x4
Post Mon Feb 18, 2019 5:32 pm
Hello guys,
I have the same issue with my Diablo T-1000, but I have Jeep GC 5.7 HEMI. Can not see device information, since it fell into the loop. Connection to PC brought no results.
My car do not start, and Diablo can't finish whatever it's doing...
NEED HELP!
Post Thu Feb 28, 2019 6:36 am
Mike Mendiburo from Diablosport support has contacted me and helped to resolve the issue.
P.S. Better to send your issues to support@diablosport.com that trying to contact them through the 'Contact form' on the website.
Post Thu Feb 28, 2019 9:25 am
cpg
Tag for future reference!
2006 Chrysler 300C RWD 5.7L Hemi
Trinity T1000
K&N 57 Series CAI
Return to Trinity Dodge Gas
