Issues with tune license on 08 f150
Trukker
Re: Issues with tune license on 08 f150
Post by Trukker »
mikel wrote:ok, sorry about that, this file should load no problem.
well this uploaded to the HH. Took it down and was able to view the custom tune file for the first time. So whatever it downloaded worked however there still is no change to any of the contents inside the folder. None of the parameters have changed. Still no tire size adjustment parameter or enable feature.
Still just
axle ratio
NOV
Tire revs per mile
same as before
that was a custom tune to correct the speedo, it wont add the parameters, we'll look further into that as well.
tech@diablosport.com
Trukker
Post by Trukker »
mikel wrote:that was a custom tune to correct the speedo, it wont add the parameters, we'll look further into that as well.
Ok now im curious. Going to have to test it later against my gps speedo and double check it with my mustang or tahoe. All of which are pretty much stock.
Curious tho...you say the attachment you gave me that i downloaded to the root of the I3 drive corrected my speedo? I never gave any info about my setup.... :shock:
the changes were there, it was just the missing VID block enable change that had to be made to allow the changes to work. It should be good to go ;)
Trukker
Post by Trukker »
mikel wrote:the changes were there, it was just the missing VID block enable change that had to be made to allow the changes to work. It should be good to go ;)
I tested it on the GPS tonite. It seems for the most part its been corrected. As i said in one of my previous posts my speedo was off by about 8mph. Now with the revisions youve made its only off by 3mph or so. So i figure i can go back in and manipulate some of the fields to get my speedo zero'd out. Thanks
Gillerroma
Post by Gillerroma »
Mike,
Having the same issue here are the files that you want linked to it. I can change the Revs Per Mile, but it has no effect on my speedo at all. Please correct this and send me the correct file.
Jerry
2005 F-150
LT 325/65R-18
open exhaust
1998 Mustang GT, PI upgrade, BBK shorty headers, BBK off road h-pipe, Trick Flow Upper Plenum, 75 mm TB, etc, etc.
did you set the vid block enable switch to disable as well?
Gillerroma
Hey Mike,
I just walked through, my tuner with one of your guys over the phone. They have had me send my files directly to them to see what is going on. Apparently, that switch your talking about only shows up on some models and it does not for mine. So your guys are working on it for me as I am typing this out to you.
Jerome
