Board index inTune i-1000 Technical Discussion inTune DCX (i-1000-DCX) Charger 2014r 6.4 superbee - issue when calibrate
Hi
I have problem when calibrate. it goes to 99% asks to OFF/ON ignition then it goes to PCM update and gives error "an error occurred when calibrating your vehicle". In attachment file info.xml.
are you sure you are performing the key cycle properly?
561-908-0040x4
Yes, we are going to "run" on the key fob, and at the end we are going off and then on.
Any update on this ? can we have some support here ? The tool updated, updated the calibration file using the agent on PC, then when going to car going thruu the proces it ends saying that during the calibration error occured. Please help
Any chance you can give us a call so we can try resetting the tuner and starting fresh?
561-908-0040x4
HI, there is a little problem , because i live in Poland , so we have like 6h time difference. Is there any other way to reset the device to stock ? Do one more time updates with agent ?
Return to inTune DCX (i-1000-DCX)
