Board index inTune i-1000 Technical Discussion Auto Updater/PC related issues PCM Calibration update needed error
Post Fri Dec 23, 2016 11:08 am
they're closed for Christmas holiday.. won't be back until Tuesday...
Technical Support
Telephone: 561-908-0040
Post Wed Feb 27, 2019 1:11 am
Am having the same problem on my Jeep the dealer probably did an update too what do I do?
Post Fri Sep 13, 2019 3:10 pm
Bought a i1000 used got it unlocked and now i am getting the pcm calibration update needed error. what do i need to do????
info.xml
(1.76 KiB) Downloaded 301 times
Post Fri Sep 13, 2019 8:24 pm
what is the year, model, engine of your vehicle????
Post Sun Feb 09, 2020 12:30 am
Hello,
I have an I-1000 DCX. My tuner worked 2 days ago then I took it into the dealership for a new thermostat. Now, I get the message:
PCM calibration for 2C3CDXHG0DH571568 might need an update. Check for a calibration update?
Update manager says my tuner is up to date...but I just get the same msg again and again.
Help!
Post Mon Feb 10, 2020 10:27 am
posty the info.xml file from the intune drive please.
561-908-0040x4
Post Mon Feb 10, 2020 8:00 pm
info.xml file attached.
Thanks!
ccbenn
info.xml
(2.33 KiB) Downloaded 212 times
Post Tue Feb 11, 2020 4:42 pm
you didn't return it to stock prior to the dealer update, so the device needs to be reset.
give us a call with it powered up and reference that I asked you to call for a reset.
561-908-0040x4
Post Tue Feb 11, 2020 6:01 pm
Thanks Mike!
I'll call Wednesday morning.
Thanks again,
ccbenn
Post Sun May 03, 2020 12:12 pm
Hi Mike,
My fuel pump failed and was towed to the dealer where they flashed the PCM. I am now having this same issue where it keeps telling me to do a calibration update but no update is found when I plug into the update agent. Attached is my info.xml. Can you help me get this solved?
info.xml
(1.8 KiB) Downloaded 39 times
Post Mon May 04, 2020 11:26 am
if you didn't restore prior to going to the dealer you'll need to call in and have the device reset first.
561-908-0040x4
Previous
Return to Auto Updater/PC related issues
