I have predator p2 u7202. It worked fine before I did an update to r69. Now my tuner doesn’t work, the update didn’t update correctly.
I removed the tune from my now parked for the season vehicle (2016 Silverado 5.3) then did an update to the tuner which I thought went smoothly. I then tried to tune my winter vehicle (2007 Tahoe 5.3) and noticed right away that the tuner wasn’t working the same ... at the tune screen when I hit ok it starts reading my truck right away with no tune select options. When it does it’s thing it says database error, update device and reboots. I later check the device info and it says status upload failed and vehicle info shows the vin from my other truck. On the ignition update program it shows status: upload failed and my silverados vin tune level: 0 installing: r247 (0 files)
I reconnected to my Silverado to see what it would do and it does the same thing as my Tahoe. When I hit tune it starts reading the vehicle without the tune select screen and when done says database error, update to tuner required. Checking vehicle info now shows 2 vehicle OS numbers and says it’s on a stock tune.
I need help to first fix the tuner so it can be properly updated with the fixed database. Then I need to see if my Silverado was actually reverted back to stock
