Dataviewer Not Displaying Analog Input
So I finally narrowed it down, I’ve been chasing an issue datalogging a 0-5v analog Input I wired up for a wideband AFR, and it’s working just fine. Even check the 2.5mm jack with a DVOM, all ok. Something seems to be up with the dataviewer software, any chance we can expect a patch anytime soon, I was made aware of this issue when I called tech support but I couldn’t get an ETA on an update that will fix the issue.
Re: Dataviewer Not Displaying Analog Input
its a bug, we are working on a solution, sorry for the delay.
tech@diablosport.com
Thanks for the reply, appreciate itmikel wrote:its a bug, we are working on a solution, sorry for the delay.
has this issue been rectified yet? i havent seen an Dataviewer update yet. i do all my tuning via email and im at the point where im switching fuels and im literally waiting on this.mikel wrote:its a bug, we are working on a solution, sorry for the delay.
do you have a current log I can look at that has the analog in it?
I don’t have a current log since updating the tool, only from trying last time. I can post that if you wishmikel wrote:do you have a current log I can look at that has the analog in it?
This should be it.
- 07082_00.log
- (326.54 KiB) Downloaded 325 times
This was from todaymikel wrote:do you have a current log I can look at that has the analog in it?
- 07082_01.log
- (35.35 KiB) Downloaded 317 times
It is displaying properly in DV 3.4.3.1 which is current.
Am I doing something wrong? I see it displaying something but it doesn’t change throughout the log, it varies barely any.mikel wrote:It is displaying properly in DV 3.4.3.1 which is current.
thats gotta be a scaling issue if the values are not correct.
I’ve tried it scaled 2 different ways, 10.0/20.0 and 10.00/20.00. PLX says those are the values to be used, and I’d agree that the scaling is off but looking at the log on my laptop the number barely changes, it’s scaling in the 10.XX area and that’s it, coasting, cruising, or full throttle.
then its not getting the correct signal.
You can monitor voltage and it should be 0-5V, if its barely changing there is something missing in the signal.
On version 3.4.4.21 external inputs are not registering. When I use the same log on a previous version of the Dataviewer it shows my external AFR input. Anyone else running into this?
Yes, we have a fix coming, sorry for the delay.
