Help intune2 ford
Help intune2 ford
Hello, I have such a problem, there is diablo intune2 after I updated it it doesn’t want to connect to the machines anymore, it says there is no license. can something be solved with this? Or just buy a new license? he is untied from the car
Re: Help intune2 ford
can you post the info.xml file from the i2 drive please?
tech@diablosport.com
yes
so what's wrong? I do not understand
well, it has an available license, can you try tuning it again and grab a pic of any errors that come up?
tried here that writes
please click continue there then post a new copy of the info.xml file so I can check this out.Alexeelte wrote:tried here that writes
WIFI ?
mikel wrote:please click continue there then post a new copy of the info.xml file so I can check this out.Alexeelte wrote:tried here that writes
I dont think the device is communicating with the vehicle.
Can you give us a call with the device powered up in the truck so we can try some things??
561-908-0040 x4
561-908-0040 x4
mikel wrote:I dont think the device is communicating with the vehicle.
561-908-0040 x4
The database is empty on the device. when connected to the update, nothing changes; one file updates and that’s it. I can’t call now unfortunately
I can’t find all the files in the downloads so that I can download and install on the devicemikel wrote:I dont think the device is communicating with the vehicle.
561-908-0040 x4
Im not sure what you are referring to, there is nothing missing from the device.
Its simply not communicating with the vehicle.
Is it possible to send me files for updating? or is support already over i2? I still made a mistake now I downloaded the launcher from i3mikel wrote:Im not sure what you are referring to, there is nothing missing from the device.
No, I am trying to explain that the issue is the fact that the devcie is not communicating with the vehicle, it is not an update issue or anything I can fix by sending you a file.
Need to determine why it can;t talk to the truck.
