Board index General Technical Support DataViewer Dataviewer Not Displaying Analog Input
Post Mon Sep 09, 2019 11:15 am
So I finally narrowed it down, I’ve been chasing an issue datalogging a 0-5v analog Input I wired up for a wideband AFR, and it’s working just fine. Even check the 2.5mm jack with a DVOM, all ok. Something seems to be up with the dataviewer software, any chance we can expect a patch anytime soon, I was made aware of this issue when I called tech support but I couldn’t get an ETA on an update that will fix the issue.
Post Mon Sep 09, 2019 11:33 am
its a bug, we are working on a solution, sorry for the delay.
561-908-0040x4
Post Tue Sep 10, 2019 10:58 am
Thanks for the reply, appreciate it
Post Mon Nov 04, 2019 11:10 pm
has this issue been rectified yet? i havent seen an Dataviewer update yet. i do all my tuning via email and im at the point where im switching fuels and im literally waiting on this.
do you have a current log I can look at that has the analog in it?
561-908-0040x4
I don’t have a current log since updating the tool, only from trying last time. I can post that if you wish
This should be it.
07082_00.log
(326.54 KiB) Downloaded 163 times
This was from today
07082_01.log
(35.35 KiB) Downloaded 161 times
It is displaying properly in DV 3.4.3.1 which is current.
561-908-0040x4
Am I doing something wrong? I see it displaying something but it doesn’t change throughout the log, it varies barely any.
thats gotta be a scaling issue if the values are not correct.
561-908-0040x4
I’ve tried it scaled 2 different ways, 10.0/20.0 and 10.00/20.00. PLX says those are the values to be used, and I’d agree that the scaling is off but looking at the log on my laptop the number barely changes, it’s scaling in the 10.XX area and that’s it, coasting, cruising, or full throttle.
then its not getting the correct signal.
You can monitor voltage and it should be 0-5V, if its barely changing there is something missing in the signal.
561-908-0040x4
Return to DataViewer
