Calibration problems
Cptek
Post by Cptek »
I purchased a used i2. it is unmarried. i downloaded all updates but when i plug in it says got to pc to update calibration. I've done this several times but it still asks for calibration update. Help!
Re: Calibration problems
please post the info.xml file from the device and provide specifics about the vehicle.
tech@diablosport.com
Cptek
Post by Cptek »
Thanks will do when I get home.
Cptek
Post by Cptek »
my car is a 2005 Chrysler 300c 5.7 awd. here is the info file you requested
Cptek wrote:my car is a 2005 Chrysler 300c 5.7 awd. here is the info file you requested
copy this file to the root of the intune drive and let the device import it then load it to the pcm then you can tune the vehicle.
Cptek
Post by Cptek »
Thank you. So plug the tuner into computer and drag it over to where my original file was? And it will over write the original file. I’m guessing.
not overwriting anything.
Just cop[y the file to the root of the drive and let the device import it.
Cptek
Post by Cptek »
I put the file on the intune. That worked, now I get no Ecu found check ignition. I keep trying then it says check cable. But it will read if there is codes in the car. What do I do now?
Cptek
Post by Cptek »
Please disregard got it working.
