T2 F150 issue
T2 F150 issue
I purchased a T2 and installed the 93 octane tune to my 2019 F150 and worked great for a couple weeks. One day while I was driving I got on the gas a bit and suddenly my truck started bucking and lost a lot of power, it threw a wrench light on my dash and the truck ran terribly. I stopped, shut it off and scanned for codes. One code came up about a torque control module and I cleared it. Shut it off than started the truck back up and all was fine. About a week went by and it did it to me again, also right as I got on the gas merging onto the highway. Just wondering if anyone else has experienced this, or if Diablo sport is aware of a fix? I can’t say enough good things about the company and the product despite this issue, just really hoping someone knows of a solution.
Re: T2 F150 issue
Is this a standard 3.5 or the HO Platinum version?
Any recollection of what the code was?
If you can load the tune to the truck then post copies of the files from the tunes folder here we'll gladly take a look.
tech@diablosport.com
Re: T2 F150 issue
It’s a standard 3.5 I should’ve taken a picture of the code but I wasn’t thinking, I don’t recall the code. I’ll figure out how to post a copy here. Thanks for the reply.
Re: T2 F150 issue
Also not sure if it’s worth mentioning but the truck also has a Roush CAI and a Rough Country cat back exhaust installed
Re: T2 F150 issue
OK, doesnt sound liek the code was related to the mods, but we'll check it out.
Re: T2 F150 issue
Hey Mike still trying to figure out how post post a copy of the tune file, but the truck actually did it to me again today and I have the code it threw and description. It does not throw an engine code but rather a wrench light on the dash, and puts the truck into what I guess you’d call “limp mode”. The code is P061B- Internal Control Module Torque Calculation Performance
Re: T2 F150 issue
I believe I did this right, hopefully these are the files your looking for.
Re: T2 F150 issue
thanks, the calibrator is going over the files.
Re: T2 F150 issue
can you please also post the backup files from the device?
Re: T2 F150 issue
here is the backup PCM file, the TCM backup isnt there im guessing because I left the trans stock. Will you need the backup TCM file as well?
Re: T2 F150 issue
No, the pcm will be fine.
Re: T2 F150 issue
please load this custom tune, should be good to go.
Re: T2 F150 issue
It did not work, did it to me right away with even less throttle. Unfortunately I will not be keeping this tuner, I just don’t think Diablo is right for my vehicle. Thank you for your help, very much appreciated.
Re: T2 F150 issue
Sorry to hear that.
We'd love to take a look at the file if you want to sort it out.
