Let us share your build!
Moderators: mikel, 06MonteSS
Re: Let us share your build!
mikel wrote: Tue Feb 23, 2021 4:59 pm Nice!
I miss my 17 SP....
You had a Dddd.... DDddoooo.. DDdooooodddd.. I can't even say it...
You had one of those boat/land-yacht turds man???!!! LOL
$20 says it would have dragged your 'Maro :)
Don't get me started on the new GT :)
tech@diablosport.com
Boo$ted392
Post by Boo$ted392 »
I miss my 17 SP in the same color....
How do you like the STS kit??
They are fun. It's been a blast to drive over my old turbo Camaro...catfish lol
LOL, I had a Catfish too :)
I had a 99 Z/28 for years. A4 car, tons of fun. Probably ran 10,000#s of Nitrous through that thing.
Went through 2 motors, a trans, last of the analog muscle cars.
Boo$ted392 wrote: Wed Feb 24, 2021 11:06 am
In case you hadn't seen, I shared your pic on our FB/IG today as well :)
Boo$ted392
mikel wrote: Wed Feb 24, 2021 3:31 pm
I didn't notice that, thanks for letting me know.
Good ole Catfish's :)
isuzu327
Post by isuzu327 »
Where to begin. I have an 07 Ram 1500 5.7l hemi.
Motor and trans
Comp cam 273h
Beehive valvesprings
Titanium pushrods
Valve locaters
Hellcat lifters
Billet double roller timing chain and gears
Ngk plugs and boots
Meledon high flo oil pump
6.1 rockers
Rocker arm locks to lock the rocker arms in place to stop valve float a high rpm's
8hp70 8 speed swap trans from a 2014 ram
Jba longtube headers with 1 7/8" primaries
True dual 3 inch exhaust all the way to the bak
6x18 inch tips
Borla atak muffler with internal x pipe
True locker in rearend for straight line gettin on it
Cat delete
MDS delete
Diablosport intune i3 tuner with a really hot street tune by Jay Greene
Body
Shaved door handles
Shaved tailgat handle
srt 10 hood from an 04 ram srt10
Custom loovers welded in on each side of hood scoop
Shaved antenna
Shaved gas filler
Tons of airbrush work
Fill gas from behind dfivers side taillight
House of Kolor Kobalt Blue paint
Door poppers for getting into the truk. Each door has one.
Train horns
Interior
Gonna have Katskins wrap all the interior with leather.
Custom Alpine and JL Audio stereo system
10.1 inch Samsung tablet for controlling stereo system and airride and has any app on it for android.
3 gauge pillar pod for trans remp, oil temp, and airride gaues.
Suspension
Parrallel 4 link in rear
MMW raised upper control arms and lower control arms with heim joint tie rod ends to fix lowered camber problems
York 210 compressor converted to an air compressor for air ride cuz i wanted a belt driven compessor instead of electric. From completely empty to 197 lbs of air pressure in just barely 3 minutes. Fills up twin air tanks, one 5 gallon up front under radiator and 7 gallon in rear where spare tire used to be. Total air in tanks is 12 gallons of air. Gotta move rear airtank inside bed cuz im building a 26 gallon fuel cell to put there. All steel braided air lines. Air mgmt is a viair valve blok with 8 valves built in.
Twin batteries that have been relocated inside bed of truck.
300 amp alternator
Big 3 wiring upgrade
All wiring for any power has been updated to 0 gauge wire.
4 percent limo tent on sides and rear and 50 percenr limo tent on windshield
24 inch wheels with 295/45/24 tires
House of Kolor Kobalt blue over top a ton of airbrush work so the airbrush work is ghosted into the paint. Ive done all this work myself with only my wife to help me. Been workin on it for abot 5 or 6 yrs and got a little more to go. Like Katskins leather throughout the whole interior.
Forge and stroke the bottom end of the motor and make it a 5.7l 396
Forged crankshaft
Forged connecting rods
Forged pistons and new rings to stand up to the forced induction. When its said and done we shuld be past the 1000 hp mark and we will c wut the future holds. But yea, this is my truk and this is pretty much everything ive done to it so for.
A 3.1l supercharger
Catchcan
And remember only my wife and myself have done the work to my truk. Noone else has ever touched it since we bought it 7 yrs ago.
Im tryin to post pics but its not lettin me.
CommanDOH
Post by CommanDOH »
Here's my '13 JKU, Ahem, Slightly Modified.... (/sarcasm)
My Mods...
Suspension/Drivetrain:
Evolution Offroad Enforcer 4" lift
EVO 4" Plush-rides
EVO Drag Link Flip Kit
FOX 2.0 Remote Reservoir shocks
FOX 2.0 Steering Stabilizer
Fox Steering Stabilizer Relocation Kit
JKS HD Track bars, Front and Rear
Rubicon Express Adjustable Control Arms x8 (Front and rear, upper and lower)
MetalCloak Outboard Shock Mount (Front)
RockKrawler Sway bar Disconnects
Metalcloak Bumpstops F/R
Rubicon Express/Rough country Bump Stop Extensions
Terraflex 1.25" Body lift
Poison Spyder Bombshell Diff Armor F/R
Powerstop Z36 Full Kit (Replacement Calipers, Drilled and Slotted Rotors, Performance pads)
EVO Front and Rear Extended Brake lines (part of Enforcer Kit)
Terraflex Brake line anchors F/R
K&N Cold Air Intake
Volante Throttle Body Spacer
DIY Oil Catch Can
Optima Yellow top
Unknown Brand 17x9 Aftermarket Rims (Purchased from a Local Club Jeep Recycle page)
Milestar Patagonia MTs 38”x13.5”R17
Most Importantly ~~
Diablo I3 Tuner (Reprogrammed for Tire Size, Shift control points, and performance, with options for "OffRoad" setting to spin up Fans)
Recovery/Air:
Superwinch 9500 w/Synthetic Rope,
Factor55 Pro-link
Warn Epic D Rings (x4)
Vault, Tow Strap, Tree Protector
Smittybuilt 2871 5.6CFM portable Compressor with Modifications (Pressure Shutoff, Converted to American standard Connections)
Custom DIY 4 wheel Inflation rig
911 Motorsports Off-Road Jack (Converted 2.5 ton Harbor Freight Racing Jack)
Bumpers/External:
EVO Pro Series Front Bumper
EVO Aluminium Rear Facia
EVO Rear Frame Mounted D Rings
EVO Protec Skid Plates
EVO Pro Series Spare Tire Mount
EVO License Relocation Bracket
LoD Destroyer JKU slider steps
Poison Spyder OEM License Plate hole Cover
Poison Spyder License plate/3rd brake light
Kentrol Front License plate mount (D Ring tow point)
Bushwacker Flat Fender Flairs F/R
Ace Engineering Front inner fender liners Front
Interior:
67 Designs JK Double Ball mount, w/ Short Cell Phone Mount (Adding iPad Mount soon)
DIY Interior Painting (Color match Components)
MPS Front Overhead Molle Panel
Door Net Panel Replacements (Hard plastic Door Pockets)
Wild Boar Solid Steel Grab Bars F/R
Tuffy Security Box (Rear Cargo Area) Color matched to the Jeep
Greyman Tactical Seat Back Molle Panels Front Driver/Passenger
Drake Fire Extinguisher mounts (front of drivers and Passenger seat)
Smittybuilt Tailgate Molle Panel
About a Dozen or more Molle Bags for all my Misc Gear including, but not limited to:
Medical Bag/First Aid Kit/2 Bleed Kits/Wound Control/CPR/Splints, Etc
Entrenching Tool/Survival Gear
Radio Gear/Headsets (CB and FRS/GMRS)
Winch controls
Recovery Straps, Ratchet Straps, Bungees
Repair kit/Tools/Heavy Gloves
Tire Repair
Several Sharp Pokey implements (Knives)
Seat Belt Cutter (Mounted on Overhead Molle Panel)
CommanDOH - AKA Bob
'13 Commando Green Jeep JKUS
38"s 4" EVO Enforcer lift, All EVO Equipped
1 Tons coming in the spring
Nice!
Billy2015GT
Post by Billy2015GT »
My 2015 Mustang GT.I got my Trinity 2 EX platinum today.
Nice, love the carbon! I'll share this one this week!
krogerfeed2
Post by krogerfeed2 »
Keep up the good work , I read few posts on this web site and I conceive that your blog is very interesting and has sets of fantastic information. krogerfeedback.click
