2017 Corvette ECM read failed
I have updated the i2, it says ECM read failed after it logs the backup, here's the info.xml
Re: 2017 Corvette ECM read failed
Are you sure the vehicle was in RUN mode by pressing/holding the push button for 8-10 seconds?
Do the same for each key on request.
tech@diablosport.com
Yep it was in run mode, i'm about to try again today. Even though I have updated the i2, every time I plug it in to the PC ignition says there is an update, is that right?
