Board index Trinity Technical Discussion General Trinity Freezing at "turn key to off"
General Trinity Support
Post Mon Apr 02, 2018 3:14 pm
Email sent last night but writing here as well...
Tried to restore original tune last night, multiple times. Went through writing to 100% and said to turn key to off. Then it stayed there, frozen, when I turned the key off.
Car unresponsive until I unplugged the tuner. Started car, drove around, tried again with same result. Both times it says last tune written is 91 oct tune, however it's not actually on there, I can feel the MDS kicking in.
Trinity T1000, 2014 Challenger R/T, 5.7L ... I used the key not the push button, battery was brand new/charged, stereo off, lights unplugged, doors closed, windows up. I've used the tuner multiple times.
There is a thin blue line running vertically down the left side of the screen, but it's been there through multiple successful tunes.
Also both times it threw codes/engine light on dash, but it does that every single time I've used it (both canned tune and restoring stock), I was able to successfully erase the codes last night both times.
Post Thu Apr 05, 2018 1:42 am
Still waiting for a response, either here or to the email I sent. I need to know what's wrong with my tuner.
Thanks.
Post Thu Apr 05, 2018 11:04 am
try a battery reset then try the restore again please.
561-908-0040x4
Post Sat Apr 07, 2018 11:09 pm
Unhooked battery, discharged, let it sit, hooked it back up and tried to reload it. Did the same thing, froze at turn key off.
What should I do now?
Thank you.
Also I tried to go to quick adjust to try and turn MDS back off in the mean time, and I don't see the option anywhere, just axle ratio/transmission/throttle is in the list. Is that normal? I've never done quick adjust, I've always just turned MDS off while loading the tune.
Post Mon Apr 09, 2018 8:23 am
MDS is not a quick adjust, its in the modify param menu.
does it allow you to restore?
are you adjusting something in quick adjust each time?
if so try with no changes.
561-908-0040x4
Post Mon Apr 09, 2018 7:02 pm
No, it won't let me restore, that's what I was originally trying to do so I could go to the dealership. I only tired to turn mds back off to see if it would let me. I didn't adjust anything in quick adjust.
Basically when I try to restore stock tune it freezes at turn key off after "writing" for about 15 mins. It goes all the way to 100%, tells me to turn key off which I do immediately and it stays on that screen.
Post Wed Apr 11, 2018 8:25 am
give us a call and we can reset the device and start over.
561-908-0040x4
Return to General Trinity
