T2-unlocked pcm issues 2017 392 challenger
Last night I installed the unlocked pcm, after install the pcm I followed the directions to start the vehicle and test the throttle. Everything went well, then I noticed that the u connect screen was blue and didn’t have some of the features my car came with. I then turned off the vehicle and noticed a Chrysler emblem on the uconnect shut down screen. Turned the vehicle back on and off a few times. Then randomly everything switched to normal,. I loaded the diablo tune, took the vehicle for a drive. When I got back home, I was unable to lick the vehicle, the panic function would randomly turn on. I then uninstalled the unlocked pcm, reinstalled it and the same things happened. I called technical support this morning and they said they’ve never heard of this happening. Please help
Re: T2-unlocked pcm issues 2017 392 challenger
Can you verify all connections were properly seated and secure?
Is it OK with the stock pcm reinstalled?
561-908-0040x4
561-908-0040x4
I was able to snap the connections closed. I reinstalled the old pcm over a break and everything worked normally
Good deal.
561-908-0040x4
561-908-0040x4
