15+ Dodge Gear Ratio Change
Very disappointed that even after the update today there's no way to configure the pcm to accept gear ratio changes. I have a 16 Charger RT which I upgraded the rear differential to a 3.90 lsd. I get trouble codes for transmission output shaft overspeed and another I can't remember at the moment. It would sure be nice to be able to configure ratios in the normal user interface.
Re: 15+ Dodge Gear Ratio Change
Well, we've never offered it as its never been necessary for any 8 speed that we have seen?
Is the speedometer incorrect with the gears installed?
Holley Technical Sales Manager
561-908-0040x4
561-908-0040x4
Speedometer is correct but the transmission doesn't select an appropriate gear during downshifting because of the transmission speed.
