2005 Dodge Magnum RT 7135 9r28 Update Issue
Moderators: mikel, 06MonteSS
BROCKET
Post by BROCKET »
I updated my ds downloader to newest version. Reset my original backup. Then downloaded 9r28 update. Installed got an error stating I could not flash serial or something like that. Found on forum I needed 9r28l. So downloaded it, used legacy connect to install. All went well and installed to predator correctly. Now when I plug it into car I get the following error when I try to install a performance tune:
Does not support Calid: 04896415AK
What should I do now? I went ahead and unplugged the predator from the car pending answer to this thread. HELP, is appreciated.
Thank you
RE: 2005 Dodge Magnum RT 7135 9r28 Update Issue
You have the same problem as I do. We can't use 9r28 or 9r28l. We're stuck with 9r12. Just reinstall that. :(
BROCKET
Post by BROCKET »
Thanks, that sucks, I was hoping to try the throttle boost function on the new update. So is it a year thing that prevents us from using it?
BROCKET
Re: RE: 2005 Dodge Magnum RT 7135 9r28 Update Issue
Post by BROCKET »
Mike_Levy wrote:You have the same problem as I do. We can't use 9r28 or 9r28l. We're stuck with 9r12. Just reinstall that. :(
Oh BTW, thanks for the super quick response. Just curiuos if they plan on updating it to allow my Cal Id or if 9r12 will just be the latest revision for me forever?
RE: Re: RE: 2005 Dodge Magnum RT 7135 9r28 Update Issue
Yeah it basically the years. The "l" CROM is limited and only has the CalIDs for 09-10 vehicles. We can't use the full size CROMs because our older Predators have less memory then the newer ones and the CROM is too big.
No idea what they're planning on doing. Its looking like 9r12 may be it for us. :(
Cruze99
Re: 2005 Dodge Magnum RT 7135 9r28 Update Issue
Post by Cruze99 »
I just updated my predator 7135 from 9r28 to 9r30 the only problem I had it said the calibration update was in that same update so this morning I went to the car and plugged my predator in and it said I had to update the calibration update so i hooked it back up to the computer and loaded the update when it was done hooked it it up to the car and it worked no problems guess I got lucky
