Board index General Technical Support General Support Driver wont install
Driver wont install
Moderators: mikel, 06MonteSS
Post Tue Sep 04, 2012 4:58 pm
predator u7135, version 9r12, windows 7 64 bit
serial to usb cable driver install fails, sets code 10. Ive tried all installers on the supplied disk, d/s website and prolific website, and multiple good driver links in other forums with no success. The cable did work last time I used it probably about 2-3 months ago but now this issue.
Any help or suggestions?
Post Thu Sep 06, 2012 10:10 am
try manually installing the driver through the device manager and browse to show it where the driver lives on your pc, that usually gets around it.
561-908-0040x4
Post Thu Sep 06, 2012 7:07 pm
I have the same problem.
I've tried using a different cable and it still doesn't recognize my Predator.
Win 7 64bit
Model # U7194
When I use the supplied cable I get the Code 10 error message.
I installed and uninstalled several drivers for it and still get the same error.
I installed through the device panel but still no luck.
Jim
Post Thu Sep 06, 2012 7:17 pm
ARe you running as an Administrator?
Post Thu Sep 06, 2012 9:43 pm
Yes.
I have been reading everything I can about it and it looks like it's a very common problem with this chipset.
Post Fri Sep 07, 2012 3:36 pm
Thanks Mike!!!
Got it fixed.
Just needed to go to the device manager and under the update driver for the cable, choose search my computer for file and then click on the let me pick the driver box.
I had to choose three or four of the prolific drivers until one of the worked.
All's good now.
Jim
Post Fri Sep 07, 2012 3:40 pm
Jim_ wrote:
Thanks Mike!!!
Got it fixed.
All's good now.
Jim
good deal.
Windows is becoming more and more difficult with these types of devices ;)
561-908-0040x4
Return to General Support
