Board index General Technical Support General Support Trinity USB drivers wont install
Moderators: mikel, 06MonteSS
Post Fri Dec 28, 2012 8:20 am
I'm using a partitioned MacBook Air so technically running windows 8. I however used vista, XP, and windows 7 to try and install the drivers with no luck. I am getting a msg that says "windows has encountered a problem while installing the driver software and to contact the manufacturer for updated information and help. The remainder of the msg reads:
"The third-party INF does not contain digital signature information"
I have no clue what that means but the DSDownloader and Data Viewer3.3 have both downloaded fine and seem to be in fully working order except I cant get the usb drivers to work so therefore can't connect my Trinity to check that function.
Post Fri Dec 28, 2012 5:46 pm
Windows 8 drivers aren't ready yet. In Windows XP, Vista or 7 you need to run it in Administrator Mode.
Post Wed Jan 02, 2013 12:59 pm
try disabling driver signing...
561-908-0040x4
Post Mon Jan 07, 2013 12:40 pm
When will the Windows 8 Trinity USB driver be available? I do not have a lower OS level pc available to me at this time.
Post Sun Jan 27, 2013 11:26 am
Yup. That worked for me. Although i had to google to find out how to disable driver signing, later i found that the steps i followed were exactly the ones listed here:
http://www.diablosport.com/download/win ... pport.html
After disabling driver signing, I was able to install the USB drivers for Trinity on Windows 8. Although i had to go to the Devices list, select Trinity and install drivers manually from Program Files location.
Return to General Support
