Wot Ltft zeroed 87 tune
Moderators: mikel, 06MonteSS
Karazysk8rx
Post by Karazysk8rx »
Had the t-1000 for 3yrs now. Recently had to put in a new motor. I've been watching parameters to make sure all is good but noticed on WOT the Ltft stays zero on 87 tune and diablo tune. Part throttle/idle ltft all is good. If I switch to stock tune modified WOT Ltft works as should. Curious if it's the 87 tune or the device. Haven't tried updating yet. Tia
Re: Wot Ltft zeroed 87 tune
that's good.. you do not want ltft's to be positive at WOT , otherwise it's adding fuel to WOT... you want the ltft's to be zero or negative at WOT... so you're fine man...
