Board index (Legacy) Predator Technical Discussion Predator Dodge Diesel power puck causing codes to pop up on 06 cummins
So I was driving into work this morning running a power puck on my 06 cummins with the switch in the 90hp position. I was just cruising with traffic when the check engine light came on and I lost all power pretty much.
I read the codes and got p0238 turbo/supercharger boost sensor A circuit high and I got p0113 Intake air temperature sensor 1 circuit high input.
I cleared the codes but havnt driven it since I had to get into work.
The is the first time driving with this unit on my truck.
any help would be awesome.
thanks
will
did you buy it used or new?
any corrosion on the connectors?
561-908-0040x4
got it from a buddy so it was used. ill check and see if there is any corrosion on the connectors. im pretty sure when I hooked it up yesterday the plugs looked good but ill look again.
will
what year was it installed on previously?
561-908-0040x4
06 also. I also have a diablo predator from the same guy but I need to do a reflash cause im getting a error saying I need to have the dealer update.
should just need to update the device to the latest versions.
561-908-0040x4
Return to Predator Dodge Diesel
