Hi, i use your product since 4 year ago! Great product....i have predator u7130 and power puck....but i just. Need know ,what is the tune who give more timing (ignition)advance ,stack tune or prédateur tune....
I use predator tune extreme(NO stack tune) + Power puck 90 hp...For daily drive...... thank
Cummins 5.9 2005
performance. tune or stack tune vs timing
Re: performance. tune or stack tune vs timing
predator tune will offer more timing.
tech@diablosport.com
I run the stack tune as too much timing on a daily driver isn't very healthy. Timing is what kills engines,injectors, and fuel pumps. You will gain a bit more power with more timing but for a daily set up, run the stack tune with the puck on when needed. I run my extreme puck all the way down with the stack tune and just crank the puck up if I feel the need to embarrass a Honda. Going to the track or if I know I'm going to run the truck hard run the extreme tune and add the puck in as it will allow as long as you don't get too much rattle. I like to keep the timing down and safe for reliability and safety.
