i dont think i got these?SILVERFORD2828 wrote:I sent the graph's from last night driving see what you think.
06 6.0 don't feel like it use to.
Tune made no difference to engine performance
I sent you an ORIS with calibration idSCGt94 wrote:Well it definitely shouldn't feel stock boys, if it does there are some bigger issues. Last guy mentioned similar problems, wound up being a ficm issue, replaced it and all was well. Feel free to blast me some oris for me to work with, i can write something more aggressive to see if its a tune issue or a truck issue.
RE: Tune made no difference to engine performance
Don C, I resent the drive data log to your email again see if anything is outta whack.
My fault. I've resent it
RE: 06 6.0 don
Don,
Sent you the logs of 2 passes.
RE: 06 6.0 don
Had any luck with my old truck?
Re: RE: 06 6.0 don
I sent you the logs post the tune you sent. Still feels like there is no tune. Goes flat @ the top of the gears.SCGt94 wrote:I believe i got back to both of you no?
RE: Re: RE: 06 6.0 don
I noticed on one truck fuel was not being added though i was commanding it. Brings me back to my ficm point, could be a possible flash that is now limiting fuel via the ficm OR parameters I have never had to mess with. I should have a 6.0 in here soon enough to mess with.
Don
2002 WS6
2002 WS6
Not sure if its my truck or the other. I should have the latest flash, it came out of the dealer last week and they said they had to flash everything to the current version.
My truck is pitiful. I pulled a 25' dual tandem gooseneck with about 15-16k on it yesterday and could only reach about 21psi of boost. I hope you guys can knock Ford's flash in the head.
Re: RE: Re: RE: 06 6.0 don
What tune was in the truck? If it isn't the stock tune, Have you tried going back to the stock tune? Wonder if that would have been better?SILVERFORD2828 wrote:My truck is pitiful. I pulled a 25' dual tandem gooseneck with about 15-16k on it yesterday and could only reach about 21psi of boost. I hope you guys can knock Ford's flash in the head.
RE: Re: RE: Re: RE: 06 6.0 don
I was runnin the stock tune when i was pullin the trailer. And i thought it was fairly powerful when i first got it. Goes to show you how a tuner spoiles a fellar.
RE: 06 6.0 don
I think the FICM flash is the issue. If you can get a 03' untouched FICM I would bet all the power from the ECU programming would come back.
