Predator says vehicle not in database for 06 Powerstroke
ibewlu725
Post by ibewlu725 »
Hello, I recently purchases a used Diablosport Predator model U7165 on Ebay. I'm trying to install a program on my 2006 F250 6.0 liter which this programmer should adapt to. After following the directions, the programmer says the vehicle is not in the database and throws a code cal id VXCF9H7. What do I need to do to make this programmer work with my truck? Thanks!
Buck02
Re: Predator says vehicle not in database for 06 Powerstroke
Post by Buck02 »
ibewlu725 wrote:Hello, I recently purchases a used Diablosport Predator model U7165 on Ebay. I'm trying to install a program on my 2006 F250 6.0 liter which this programmer should adapt to. After following the directions, the programmer says the vehicle is not in the database and throws a code cal id VXCF9H7. What do I need to do to make this programmer work with my truck? Thanks!
Have you tried updating your Tool with DSdownloader?
u7165_pcm_6_0-9r14.crom
(940.91 KiB) Downloaded 386 times
