U7186 no serial flash found
Tried updating to 9v15, and went most of the way to update and on reboot got the Incompatible hardware, no serial flash found. Researched and found the thing to do is go back to the 9v08, but i cant get the DSdownloader to recognize the Predator. How do I get it to recognize it so i can load the 9v08 file? Do I have to call support to get to that point?
use legacy connect to load 9r08, there are instruction on DSDL for 'application missing or corrupt', they will alk you through it.
- u7186_dmx_lly_lbz-9r08.crom
- (767.45 KiB) Downloaded 249 times
tech@diablosport.com
correct, 9r08 is as new as that tool will go
