Dataview software not working for me
I wanted to check out the data reviewing capabilities of the unit prior to purchasing, but for some reason it crashes when i try to load either one of the two sample log files. It works fine for me at work, but obviously I need it to work here at home. It doesn't crash to desktop, it just sits at the loading dialog and locks up.
Any ideas?
Running
XP Pro version 2002 Service Pack 2
AMD 3700+
2gig ram
SATA hardrive
NVIDIA GeForce 7800GT's in SLI mode (tried just running one, no diff)
Any ideas?
Running
AMD 3700+
2gig ram
SATA hardrive
I am running an NVIDIA 6800GT as well as an NVIDIA 5600 and the data viewer works fine. Maybe the install of the dataviewer software had an issue. Uninstall the dv software, delete the install directory, reboot and reinstall it. Also check to see what is running in the background on the PC.
05 GTO - M6
U7191 ver 9r02
08 - Avalanche LTZ
i1000 ver 1r04g
U7191 ver 9r02
08 - Avalanche LTZ
i1000 ver 1r04g
Thanks for the info. Gave it a try, still no go.Goatluver wrote:I am running an NVIDIA 6800GT as well as an NVIDIA 5600 and the data viewer works fine. Maybe the install of the dataviewer software had an issue. Uninstall the dv software, delete the install directory, reboot and reinstall it. Also check to see what is running in the background on the PC.
Any chance I can get an older version of the software? Maybe an older version will work for me. I really want to get a tuning option, and I like the predator as an option, I just can't see purchasing when the software wont work for me, and that to me is its most important aspect in tuning properly.
If I'm forced to get a wideband recording option, i might as well go for one of the other tuning options.
thanks
thanks
The 3.1 version of the DataViewer is around the corner. There have been no interim releases to the 3.0 DataViewer because of the work going into 3.1. 3.1 fixes most of the problems that some people are seeing.
Note that you can log real-time data on the Predator just fine without the DataViewer.
johnc <at> diablosport.com
Thanks, I'll hold out a little longer running rich until your new software is released.johnc wrote:The 3.1 version of the DataViewer is around the corner. There have been no interim releases to the 3.0 DataViewer because of the work going into 3.1. 3.1 fixes most of the problems that some people are seeing.
Take a look at the new DataViewer forum at the bottom of the Technical Discussion section. A Beta download is available from there. Note that the 7194 is supported by the 3.1 DataViewer Beta. If this Download still gives you problems, I would like to work with you and try and figure out where the problem lies.jsk06c6 wrote:Thanks, I'll hold out a little longer running rich until your new software is released.
IT WORKS!!!! Great job, time to get the 7194 this week. Thank you!!johnc wrote: Take a look at the new DataViewer forum at the bottom of the Technical Discussion section. A Beta download is available from there. Note that the 7194 is supported by the 3.1 DataViewer Beta. If this Download still gives you problems, I would like to work with you and try and figure out where the problem lies.
Only thing thats odd is after quiting the application, it shows up as still running in the Windows Task Manager Processes tab. If I try to restart the application it crashes with a error. But if I end the dataview.exe process still running, and then try to start, it starts up without a problem. Definitely an easy workaround, and I can certainly live with it. Great application, can't wait to get the programmer now!!
Awesome...thanks John!jsk06c6 wrote:IT WORKS!!!! Great job, time to get the 7194 this week. Thank you!!johnc wrote: Take a look at the new DataViewer forum at the bottom of the Technical Discussion section. A Beta download is available from there. Note that the 7194 is supported by the 3.1 DataViewer Beta. If this Download still gives you problems, I would like to work with you and try and figure out where the problem lies.
