Hey guys,
Trying to get my Wideband input to log in DV but im never seeing the analog input show up in DV. I know my wiring is good, tested that with a multimeter. I believe I set up the analog input in the i3 correctly following suit of another forum post I've seen using AEM 30-0300 WB. Any help would be appreciated. Thank you.
Analog Input not showing in DV
Re: Analog Input not showing in DV
can you post a log that has the Analog in it?
tech@diablosport.com
Heres a couple logs. I cannot get the external inputs to show up in DV for the life of me.
- 30670_15.log
- (77.63 KiB) Downloaded 59 times
- 30670_14.log
- (193.8 KiB) Downloaded 67 times
- 30670_13.log
- (1.8 MiB) Downloaded 59 times
I had our dev team look into this and none of these logs have any analog data recorded in them.
The analog is configured in the tool but nothing is recorded.
Make sure the wiring is correct, confirm you are getting 0-5V at the tip, and try configuring both channels the same way.
