Fuel Injector Pulse Width Logging
Need to Log Fuel Injector pulse width for my 2014 Challenger R/T.
This is required by my CMR tuner.
On my trinity I have the Injector Pulse width Cylinder 1 to be read but it doesn't.
The dataviewer shows no readings?
is it Dodge that does not allow this feature to be read?
or is there an update in the near future form Diablosport?
Any suggestions?
Any suggestions?
Re: Fuel Injector Pulse Width Logging
this should work with the latest 33012 version of DV.
tech@diablosport.com
Mike,
I just downloaded and installed Dataviewer 3.3.0.12
I viewed my one of my logs and got the same results with the Injector Pulse Width at "0".
Am I doing something wrong here?
was the log recorded to an old dv version or to the tool?
if logged to the tool, is it up to date?
Mike,
initially it was recorded with the Trinity and viewed with the old version Dataviewer.
then installed the new Dataviewer v 3.3.0.12 and utilized the same log.
Tools are up to date:
Trinity 1000 = 1r13.crom
Dataviewer = v 3.3.0.12
DS downloader = v2.2.2.7
stream a new log to dv.
tool should be on 1r13c as well.
Mike,
I recorded a new log at idle for one minute using my Trinity hand held.
Then viewed it on my Dataviewer v3.3.0.12
the readings are at "0" for Injector Pulse Width Cylinder 1 (us).
Still no luck...
Trinity v.1r13c
Still no luck...
Trinity v.1r13c
Mike,
I re-installed the Dataviewer 3.3.0.12 software from Diablosport Download page.
When installed I noticed on the Dataviewer tabs I clicked on Help>About Dataviewer>
DataViewer Version 3.3.0.11
Build: Sep 19 2014
could this be the problem?
Build: Sep 19 2014
Update...
I successfully record the Injector Pulse Width on my 2014 Dodge Challenger R/T Using the Dataviewer.
Thanks Mike
Thanks Mike
good deal.
How did you get it to change to the 12 version from the 11? I also updated to 33012 but in the help menu it still says version 11
A.V.GCSRT8:
My Dataviewer Version is still 3.3.0.11 looking at it from the help menu. It never changed.
What did you do different to get it to log then? Mine doesn't seem to work still. On the c crom now also. Gonna have to play with it I guess. Unless the 6.4 is different than your r/t and that's the reason but I doubt it
A.V.GCSRT8 ,
I had already installed the updated Crom v 1r13c on my Trinity so I didn't really have to mess with this again.
I installed the Dataviewer V 3.3.0.12 software.
once this was all updated.
in the car..
1. connected the Trinity to the vehicle via OBD II.
2. connected the usb cable to the trinity and to the laptop.
3. Since I have a wideband O2 sensor, I also connected the audio jack to the Trinity.
4. Vehicle: Power on engine off.
To get a better picture I had multiple wires connected to the trinity at this point.
5. laptop: I initiated the Dataviewer 3.3.0.12 but the help tab still shows 3.3.0.11 hmmm??
6. Dataviewer: click on "Real Time Data Mode" (Lightning Bolt)
7. You will see an enormous amount of pids to choose from. I went crazy here and chose all the ones the my CMR tuner required to view.
8. Start your engine.
Once you have all your pids click on "Record" (red circle)
This is it... hope this helps.
This
in the car..
This
Is injector pulse on the t1000???mikel wrote:this should work with the latest 33012 version of DV.
