Hi,
i saw some threads with some pretty similar issues but since i'm not sure if I should reply to one on them or not, I decided to start a new one..
I have a 2010 dodge challenger 5.7L automatic, with the trinity T-1000.
I went to the Dealer to fix something and they Flashed my car at the same time because it had a recall (the air bag sensibility issue)
I made sure to reinstall the stock tune on my car before going (just in case..)
now when I Plug the trinity on my car, i get "your calibration is 68052005AF and it is not supported. We need to downgrade to 68052005AD in order to continue".
(see the attached photo)
I pressed on "agree" then It gave another message "Please connect this Trinity to the DS DOwnloader program at your PC and clics the calibration Updater button to update your vehicle to a supported CAL ID"
(i've also attached a photo).
I went to my computer downloaded the later version of the DC downloader, plugged my Trinity, did the calibration update then went back to my car, plugged the trinity and received the same thing again.
I went back inside, plugged the trinity to the computer again, went back to the car and still the same message.
am i doing something wrong?
Calibration not supported
- trinity1.png (897.27 KiB) Viewed 2717 times
- trinity2.png (754.64 KiB) Viewed 2717 times
Re: Calibration not supported
nobody know what to do?
connect to a pc and open dsdownloader and let it connect to the tool then click the calibration updater button to download the file, then load it to the car from the performance menu.
tech@diablosport.com
When I plugged the device on my comp, the downloader downloaded an update again and this time when I plugged the device in my car, it worked!
this week/last week's update fixed my issue.
thanks!
thanks!
How did you get the update to load. I connected mine to my pc but I don't get any message about an update.Bastt wrote:When I finally got VyprVPN and plugged the device on my comp, the downloader downloaded an update again and this time when I plugged the device in my car, it worked!
thanks!
