Down grade with cruise on trans bucks back
Post your Cummins related Trinity questions here.
dreich
Post by dreich »
U7130
9R09
2004.5 Dodge Ram 3500 Diesel
The truck has 58000 miles on it and I'm the original owner.
I just bought the Predator and installed the performance program. Took a 140 mile trip and held it on cruise @ 59 MPH and used 5 gals. = 28 miles per gallon. Outside air temp 59-65. Was getting 22-23 with the stock system at the same speed. If I ran the truck @ 70 MPH with the stock unit I would get approx. 19 MPG. With the Predator it bumped it to 22.1 @ 70 on the return trip.
My problem is that there were a lot of up hills and down hills on I-5 in Oregon. When the truck starts down a grade (doesn't make any difference if it is an easy grade or steep) the truck starts to buck almost like when a motor is misfiring. If I press the button to disengage the cruise the bucking quits. When I get to the bottom of the grade I engage the cruise again and everything returns to normal. I tried to ignore it at first but it felt like I was going to tear the trans apart. I was not towing anything and only had a two hundred pound item in the bed of the truck.
RE: Down grade with cruise on trans bucks back
I cant say I recall ever hearing about htis, but we'll check it out.
can you go to options/troubleshooting/show calid and post that up please?
also, if you get a chance, see if the other tunes act the same way.
Holley Technical Sales Manager
561-908-0040x4
CDH776
Post by CDH776 »
Mine does this too. i have a 04.5 with 146k miles, so i thought it was something to do with my injectors or somthing. but now seeing someone else with the same problem now i know its not. but as soon as i take the tune off its fine.
Zacht91
Re: Down grade with cruise on trans bucks back
Post by Zacht91 »
My truck does this sometimes and its stock. I think its just the cruise trying to slow down to stay at that speed.
Zacht91 wrote:My truck does this sometimes and its stock. I think its just the cruise trying to slow down to stay at that speed.
likely the converter bucking...
561-908-0040x4
