trinity won communicate with ecm
Bought this Turner and it keeps saying can't communicate with the ecm ? What could be the issue I called and talked to the tech support but he tells me I must have a electrical problem in my truck
Re: trinity won communicate with ecm
Diablo where are you ?
what truck?
tech@diablosport.com
2005 gmc duramax has the lly motor
what does it show for options/show info, part?
Serial. 6jr09cf-1
Part. Gm_can_diesel
Version. V.1r08
Hardware. Trinity
Bus. Can
Born. 03/02/2011. 19970
Bus test. Not done
Saved . Calid
Part. Gm_can_diesel
Version. V.1r08
Hardware. Trinity
Bus. Can
Bus test. Not done
Saved . Calid
1, it needs to be updated.
2. The wrong vehicle has been selected, options/change vehicle type and select the correct year, etc.
When I go in to change the vechile it won't even offer the gmc 2500 hd duramax, what update do I need and where do I get it
the current dsdownloader software should update the tool automatically if it is registered when connected on a PC.
I can't select my truck
$828 for this programmer and it's this hard to get installed
Trinity retails for $599...and if you purchased it new, on that software revision, I apologize but its been sitting on a shelf for about 4 years, maybe more, so it will need a little extra updating to get it going, but nothing too difficult.
WHat happens when you try to select your vehicle?
$828 for me here in Canada and there is no gmc under 2005 section so I tried to do the update but my laptop won't pick up the programmer ? What version am I looking for?
the dsdownloader will update it automatically.
If its not finding the tool, install the driver here:
https://www.diablosport.com/download/so ... er_2.4.exe
3 computers with the 2.4 downloaded and it still won't pick up the tool , totally disgusted
