2002 Camaro rear gear ratio
I do not have the option to adjust for different rear gear ratios? Was this option not included for the Itune1000? If it is, how do I access it? Updates have been completed.
Re: 2002 Camaro rear gear ratio
I would expect it to be there.
tech@diablosport.com
Option is not there and I have two Itune1000, both are updated...
post the last tune written here and tell us what the stock and new gear ratios are and we'll adjust it for you.
Haven't installed the gears yet, but would like to have the feature unlocked so that I can adjust the speedo. Thanks
I have attached the last written tune. Currently have 3.23 will be installing 3.73 rear gears. Thanks!
- PCM_09358576_LastTuneWritten.grg
- (26.89 KiB) Downloaded 66 times
On it.
And here you go, new tune set up for use with 3.73
- PCM_09358576_MOD1.grg
- (24.75 KiB) Downloaded 71 times
Thanks Mike
