Jeep GC 5.7 2008
I unlocked the license, then dealer made PCM upgrade to 05187310AJ. After this, when I wanted to use the I1000 back, went to the "write tune", received the following message:
"PCM Calibration for [VIN] might need an update. Check for Calibration update?"
I disconnect the device from the OBD, then connect to the PC, I use the Ignition Updater software.
After checking update, it shown message: Check back soon for downloadable content for your device!
I tried this process 4-5 times with the same exact outcome.
What am I doing wrong ???
Info.xml in attachment
Wont update DCX - Jeep GC 5.7 2008
Re: Wont update DCX - Jeep GC 5.7 2008
Ok, today I checked again for Ignition updates for my device. This time the device got some updates and loaded new calibrations.
I'll check it in the car and I see if it works...
should be good to go, let me know.
tech@diablosport.com
