Hello, i received my i2 earlier today and updated it with Ignition. I attempted to connect to my truck (2014 Ram 1500 5.7L 8speed crew cab short bed) and was stuck on the please wait screen, so i did some digging around on here and a file to drop onto it so it would fix that issue. After that i had a message that said it was not supported and that it needed to be updated. Did that then had to load the 1st fix onto it again to get past the please wait screen. Now I'm having trouble doing an advanced tune with my i2. It attempts to read the PCM and says its unable to read. Also the only parameters that I'm allowed to change are the tire size and traction control?? Is this normal?? How do i disable MDS and also how do i load the advanced tune? Is there another update or file that I'm missing??
I was successful at doing the quick 93octane tune however and changing the speed limiter and tire size.
Please help 2014 Ram 1500 8speed
Re: Please help 2014 Ram 1500 8speed
it looks like you adjusted some quick adjust settings maybe?
Please go to quick adjust and select restore quick adjust then post a fresh copy of the info file without updating again.
tech@diablosport.com
I did adjust the tire size prior to attempting that, do you think that could have caused it to not read? I'll do it when I get home from work tomorrow morning (I work 24s) and post the file.mikel wrote:it looks like you adjusted some quick adjust settings maybe?
Here is the new file. I was able to do the Diablo* tune this morning once i reset the quick adjusts. MDS still doesn't show up though. I did the "skip" on the 2nd screen after selecting the diablo one. Is this the correct process? Or should i have selected modify stock tune??
are you sure you are looking in the menu titled 'modify parameters' in the advanced menu, not quick adjust?
These are the only 2 I'm able to see under advanced tune.mikel wrote:are you sure you are looking in the menu titled 'modify parameters' in the advanced menu, not quick adjust?
you are not in the advanced menu, you have to click advanced tune to get in there.
Once I click advanced tune it shows adjust parameters but I'm unable to click them.mikel wrote:you are not in the advanced menu, you have to click advanced tune to get in there.
