No Data logging
345WK2
No Data logging
Post by 345WK2 »
I updated my I3 and went out to my Jeep and Hooked it up to do some data logging and it wont record anything to the unit itsself. If I run it with my laptop hooked up to it, it will record the data and I can view it in real time. When its just the I3 hooked up the live data doesn't show and it doesn't save to the log file. It worked in the past so I can only assume the latest update changed something?
Info file is attached
Re: No Data logging
2011 JK?
What do you see what you go to the logging menu and select record?
tech@diablosport.com
345WK2
Re: No Data logging
Post by 345WK2 »
2011 WK2 5.7 hemi
When I hit record it takes longer than normal for the data to pop up on the I3 screen and It is showing a ton of PIDs that I have never added and the value on everything is zero or -40 or whatever. STFT and LTFT are like -100. I can grab a pic of it if you need, but its like im hooked up but its just not able to read any of the values in the PIDs
345WK2
Re: No Data logging
Post by 345WK2 »
Also, It has no problems installing the factory tune and then I went and put the Diablo tune back in it and changed parameters and it had no problem loading any of the tunes. Operated just like it normally does for tuning.
Re: No Data logging
can you record a quick log and post it here so we can sort this out?
345WK2
Re: No Data logging
Post by 345WK2 »
I can try. It will only record when I have my laptop hooked up to it. If its just the I3 it wont save anything because its not "seeing" anything. Hopefully you get what I mean. Ill run out to the Jeep now and see if it willo log just by itsself
Re: No Data logging
dont worry about it, we found a bug, it should be fixed soon.
345WK2
Re: No Data logging
Post by 345WK2 »
Cool. TY. I was starting to think maybe I was crazy.
The jeep is running and i3 is hooked up to the obd port
Re: No Data logging
Saw the same on my 17 Charger :(
345WK2
Re: No Data logging
Post by 345WK2 »
Any update on this? Ive done the updater and still have the same issue. Thanks
Re: No Data logging
Looking for an update today or tomorrow ideally.
Re: No Data logging
this is fixed, please update and you can log again :)
345WK2
Re: No Data logging
Post by 345WK2 »
Thanks Mike!
